Visa Set Properties error on PDA
Hi, I am using a bluetooth DAQ card to acquire data and write it to a PDA application.
I have written the code in labview and have run it succesfully on my laptop. I am using the VISA VI's and virtual serial port to communicate with my bluetooth device.
The outgoing PORT number on the PDA for the device is 8 so I have fed this into the open visa connection VI. See attached jpg.
When I try to run the application on the PDA, I get an error : Code -1073807343 and message Visa set properties.
Can anyone help?
(3,696 Views)
What version of LabVIEW PDA are you using? Did you install support for NI-VISA on the PDA?
Try using ASRL1::INSTR as the VISA Resource Name for COM port 1.Alternatively, you might be able to use the VISA Find Resource VI to search and retrieve a specific resource or all available VISA resources.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,678 Views)
Labview mobile module 8.6. the PDA is operating Windows mobile 6. Yes I have installed NI-VISA ont he PDA.
I have tried as you suggested. I used the VISA find resource VI and found ASRL1::INSTR. I then fed this to the open VISA connection VI. I now get the same error code but the source is now VISA write.
(3,647 Views)
I have fixed the below as I should have used ASRL8::INSTR to my VISA open connection.
However when I run the application ont he pDA, it crashes without reason after a few iterations of the loop. I have attahced my code to see if anyone can shed some light on why?
(3,639 Views)
Hi jamie310382.
May I ask you how do you install NI-VISA on the PDA?
I ask because I try to install NI-VISA to smartphone (Samsung i607 - windows mobile 5)  but it failed
The error is "this installation file is not intended for this device."
I also try on another phone with WM 6.0 (same error)
Do I need to do anything before I can run installation?
Computer XP service pack3
Device Samsung, Q phone (WM 5.0or 6.0)
Activesync 4.5
Labview 8.6
NI-VISA 4.4 (I try all version 4.5; 4.6 same error)
Thank you for your help.
TP
(3,486 Views)
Jamie,
I had the same issue and I could not fix it.
Apparently VISA works fine on a PC and does not work properly on a PDA. I think this is one of those known issues reported by NI.
I fed a string COM8 into basic serial communication and it worked fine.
Watch out because the read and write to serial require visa so you have to be consistent.
Take care
(3,467 Views)
