Visa port speed
Hi Paolo
Many thanks
I will test it later and will send a feedback from your help.
Once again, many thanks.
Best regards
CPalka
Message 21 of 28
(1,648 Views)
Hi Bill
Sorry, I could not understand your message.
Best regards
Cpalka
Message 22 of 28
(1,647 Views)
Hi Paolo
Sorry for the inconvenience, but my Labview version is 2013, can you please save a version for that?
Best regards
CPalka
Message 23 of 28
(1,633 Views)
Accepted by cpalka
Here it is.
Paolo
Message 24 of 28
(1,617 Views)
Hi Paolo
Once again many thanks.
I saw what you have done, later I will change all code and send you feedback.
I will never  get this solution alone, with you help I will increase my knowldge in labview programming.
Best regards
cpalka
Message 25 of 28
(1,609 Views)
@cpalka wrote:
Hi Bill
Best regards
Cpalka
I meant that not using labels for your front panel objects not only makes it difficult for humans to understand your code, it could also cause confusion in the compiler, which is never a good thing.
Bill
CLD
(Mid-Level minion.)
Message 26 of 28
(1,596 Views)
Hi Paolo
It works fine!!! It is very fast changing the state.
Many thanks
Best regards
Cpalka
Message 27 of 28
(1,576 Views)
Hi Bill
Doing this changing in vi with help of Paolo, I could understand your comment. I need to put the label again to creat the even structures.
Many many years ago I start with LB Basic I, after that I learn with by myself and helps in this forum.
I am a researcher, and I need to do the tests, create VIs to help me in this researches.
I feel sad that our students does not enter in LB programming and University do not "open ways" to start with it and since some years do not pay anymore the licenses.
That's why I am a fighter to still using LB, and because we have a lot of hardware from NI.
Best regards
cpalka
Message 28 of 28
(1,572 Views)
