01-22-2013 07:30 AM
Hello, can somebody help me to find what the problem is.
I build a small program using a RS232 to comunicate with a GE PLC using a SNP-X protocol.
I have used a Serial Configuration.vi with a "Visa Resource Name" Control. I build a executable of my program and a installer.
I installed it on a pc that has no Labview version on it and i can not see my Com Ports in the "Visa Resource Name" Control.
I have this problem on two pc's.
When i install the program on my pc where i wrote the program and Labview is installed it works without any problems.
I hope someone have a good idea.
01-22-2013 09:17 AM
Did you include NI-VISA runtime in your installer? MAX? Just like requiring the LabVIEW runtime, you must include all hardware drivers. What error code are you getting?
01-24-2013 01:45 AM
I will check it later today if i included the visa driver to my executable, i am not shure.
I do not get any error messages the program is running but when i try to connect i build a dialogue for inputting all settings of the com port and here
in the "visa resource name" control my com ports will not be shown.
Only the "Refrech" option is shown.
When i go to windows device manager I could see that my 2 Serial Com ports where set correctly and are working properly.
Also if i start "Hyperterminal" i can acces both com ports.
So it could be a missing driver I go and check it,
01-25-2013 07:22 AM
And what was the result?
