Visable Property Node Question
You should mark whatever message that helped you most as the solution to your question rather than your own thank you message.  Whether that was Altenbach's idea of using clusters or Phil's example of how to use references in a loop.
First you will have to go to the options menu to the upper right of your message to unmark it as the solution.
Message 11 of 12
(617 Views)
Okay update made, I gave it to Phil cause I think his idea helped me a little more on how to group them together, which is more of what I wanted when dealing with the original problem. I definitly do appreciate all the help.
Message 12 of 12
(595 Views)
