Vision Acquisition Express must be launched from LabVIEW
I am trying to run a code which uses the vision acquisition express VI and get the attached error message when double clicking on the block - a window enabling you to change camera parameters should pop up at this stage. The same error comes up when selecting the same block in a blank VI. There is not a problem with the code as it works on 3 other computers I have tried, seems to be specific to my computer, but have uninstalled then reinstalled LabVIEW and the problem still persists - any ideas of other things to try?
Many thanks!
Message 1 of 15
(4,569 Views)
Well, you could attach your VI (instead of pictures of part of your VI) so we could try it and see if we have the same problem, then look to see why ...
Does the machine where the software fails have the Vision Licenses installed?
Bob Schor
Message 2 of 15
(4,525 Views)
Hi Katie,
Have you installed the correct vision acquisition software?
Could you provide us an NI Max report of you PC?
check here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9mPSAS
Message 3 of 15
(4,521 Views)
Attached is NI max report - please let me know if this is what you require!
Message 4 of 15
(4,513 Views)
Attached is the VI. I believe the correct licences are installed as all other aspects of vision are functioning correctly.
Message 5 of 15
(4,509 Views)
This is a somewhat complex VI, and the notes on the Front Panel sound like you are planning on making it even more complex ("More cameras").
So what happens if you "simplify", i.e. write some code that uses a single camera and does the first few steps of acquiring and tracking objects?  Does it work?  As you add in more stuff, is there a place where it "breaks"?
Bob Schor
Message 6 of 15
(4,499 Views)
It is just the vision acquisition express block that has the issue. Even starting a blank VI and putting in this block alone and double clicking gives the same error message. The code isn't the issue as it works on other computers - seems to be something specific to my computer.
Message 7 of 15
(4,491 Views)
Have you tried uninstalling Vision Acquisition Software and reinstalled that?  If so, have you used the KB for forced reinstalling NI software?
Message 8 of 15
(4,488 Views)
Yes tried reinstalling but this didn't solve the issue.
Message 9 of 15
(4,474 Views)
And have you confirmed that you have a valid Vision license?
There is a difference between using the Vision driver vi's and the Vision Module vi's, like the express vi that you are using.
Message 10 of 15
(4,468 Views)
