Vision Assistant - .bin not found
Thought I'd try here first before raising a support call on the off chance someone's come across it before.
Running Win7 64bit and LV 2013 SP1 (via 2014 DS SP1), with the Vision Development System installed. I have a fully-populated Vision palette, and can use the low level Vision VIs to my heart's content...
However, I can't seem to run Vision Assistant. On dropping the Vision Assistant from the palette, I get the following two errors:
I am also unable to open previously configured Vision Assistant instances in other code, although no errors are returned - the VA just doesn't run.
I also have LV 2012 SP1 installed (amongst other older versions) and now get the same error with that. I haven't tried to use VA since I switched to LV 2013 several months ago.
Has anyone come across this before?
I'm just trying to repair Vision Assistant 2013, which I'd like to think will fix it, but we shall see. I'll let you know when all 117 of the requisite components are also finished repairing Smiley Mad
CLA
(6,265 Views)
Accepted by topic author thoult
The repair solves it.
Sadly, that involved repairing components for 2013, 2012, 2011, 2010... but still, at least I got to put my feet up for a little while whilst it was completing.
Will mark as solved in case anyone else has the same issue.
CLA
(6,255 Views)
