Vision Assistant scripts to Vision Builder AI conversion
Hi Everybody,
I started a project to move from using Vision Assistant express vi to Vision Builder AI, I hope somebody already did this step because I have some questions:
1) Is possible to convert the scripts saved in Vision Assistant to Vision Builder or to import it? I'm searching a way to don't have to do that manually since the tools are almost the same.
2) Is possible to integrate the Vision Builder interface in a labview project? I would like to just display the program in the main HMI instead of open Vision Builder like a separate program.
Thank you!
(3,083 Views)
Yes you can convert the vision assistant scripts to vi by selecting "Create Labview VI" from the tools menu in vision assistant.
You can also add it in a project once you have created a vi.
CLD Using LabVIEW since 2013
(3,033 Views)
Thank you for your reply!
Unfortunately I have some scripts saved with Vision Assistant, and I need to convert them to Vision Builder, is not the same situation you described.
(3,022 Views)
