Wireless Vibration Sensor with Azure IOT Hub
Hey I have been working with new wireless sensor, I am trying to connect this sensor with computer and monitoring the readings with the help of utility software provided by this company which is running on lab-view
But Need to know the alternative way which help to connect the sensor readings while interfacing with particle photon and get the readings connect to Azure IOT Hub which display the dash board of readings of sensors by using web based applications
I  have never worked in this kind of implementation, so your leads will be much appreciated
Message 1 of 1
(2,375 Views)
