Vision and Motion VIs missing
I have installed (in order):
-LabVIEW 2013 PDS 64 bit
-Vision Development Module 2011 64 bit
-LabVIEW 2011 PDS
The Vision and Motion palette is visible in both 2011 and 2013. But in 2013 the palatte is empty.
Could i get this to work?
(4,773 Views)
Hi Marvin,
you should install the 2013 version of all modules when you want to have their support functions in LV2013…
(4,753 Views)
so you say it is not possible to use the vison development kit in an earlier version?
I only have a licence for the 2011 version, otherwise i would follow yor suggestion.
(4,746 Views)
Hi Marvin,
when you have a Vision license for the 2011 version you need to use that version.
When you want to use vision with LV2013 you need to update your license…
Why do you even expect a 2011 version to work in a 2013 environment?
(4,739 Views)
(4,731 Views)
Accepted by nollMarvin
Hi Marvin,
in your case the first picture applies: LabVIEW vs. VISION!
And it clearly shows: you can use any VISION version starting from VISION2011 with LabVIEW2011.
But to use LabVIEW2013 you need to install VISION2013 (or more recent).
(4,723 Views)
