Vision inspection
Hi, I am new to Machine vision. In VBAI, how can i inspect an object that is perfect or damaged. For instance i have attached two images in which one is a normal wall and another one is a cracked wall. What are the steps involved in finding those objects that are cracked. Thanks in advance!
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(3,547 Views)
I was trying to figure out where the cracks are..! 😄
You can go through the tutorials available in NI related to VBAI.
https://www.ni.com/docs/en-US/bundle/373379h/resource/373379h.pdf
Also there are examples available in your VBAI start screen (Go through them)
Hint for your Processing: YOu can use thresholding and then particle analysis for the cracks (If i am not wrong with the cracks available in the images that you provided)
(3,537 Views)
Do you consider yourself a "pretty good LabVIEW Programmer"?  Could you pass a CLAD (the lowest Certification level) exam with confidence?  Unless you can answer "Yes, and I can even pass the CLD exam!", you may be in for some "interesting challenges", as NI Vision is, shall we say, a "more-advanced" topic.
Regarding those "two" images -- looking at the three Images you attached (two of which might be the same), I'm not sure I could identify the "normal" and "cracked" wall.  Of course, I'm probably not as smart as good LabVIEW code ...
(3,536 Views)
