Visual Calendar
Is there any module of a visual calendar that i can put in vi or
something like that?
The vi should ask the user to input a time and date interval.
Thank you.
(5,001 Views)
There is a Microsoft ActiveX control called monthview that gives a nice calendar image. You will need to look on MS webpage to get detailed information on whot to use the control. I attached a trivial VI with te control already inserted in an ActiveX container so you can see what it looks like. It may not work on your machine if you do not have the same control as I have. I did not implement any coding for querying the user.
You may also want to search NI's site (advanced search) for calendar . There are a bunch of discussion hits on the issue.
(5,001 Views)
LabVIEW 7 has a calander control - drop a time stamp control on your front panel (control palette>numeric>time stamp), and then click the button next to the control.
Copyright © 2004-2026 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(5,001 Views)
Control could not be loaded...
Mohit Monga
(4,282 Views)
Posting to such an old thread with absolutely no details is not a very good way to get a quesiton answered.
(4,263 Views)
