Vivado HLS ended abnormally
I just installed LV 2014  32 bit and the FPGA module for LV 2014. I also installed 2014Xilinx14_7.
I can create directives from a VI. However, when I run "quick estimate" on the selected directive, suffered from an error of
"FPGA IP Builder: Internal error: Vivado HLS ended abnormally. "
The same propgram works well unver LV 2012.
Any suggestions?
(3,141 Views)
The final compilation using these directives can pass successfully.
(3,126 Views)
Hi Ling
What target are you compling for? Also do you have a screen shot of the error message?
James
(3,094 Views)
Hi, James
The device is PCIe-7842R. Please see the screen copy.
As I see in the below link, LV2014 should support vector and matrix operation, such as dot product. However, I don't see them in my system.
thanks
(3,087 Views)
