WANT TO CLEAR GRAPH, AND TABLE EVEN SEQUENCE STRUCTURE IS NOT RUNNING.
Probe 37 will always be an empty array. With every start, it clears the array from the shift regsiter an places new data. Once data is acquired, you can save it. If you press clear, the data in the shift regsiter is again an empty array and there is nothing to save.
Message 11 of 16
(944 Views)
@gj;AKLDFJG wrote:
And one thing more I can save this data in what kind of formats?
You can save the data in any format you desire.
Message 12 of 16
(943 Views)
hey, I am telling you there is no data flow in that direction. I am attaching a new snapshot for this.
Message 13 of 16
(936 Views)
Sorry snapshot didn't got attached in last reply.
Message 14 of 16
(931 Views)
Accepted by topic author GJAKLDFJG
Ah, sorry, there is a small oversight. In the "clear" case structure, wire the array across in the false case and delete the array wire in the true case. All better?
Message 15 of 16
(924 Views)
hey it did worked, thanks a lot...
Message 16 of 16
(914 Views)
