WARNING SIGN ON I/Os of connectors of fpga target RIO0, PCI-7831r IN LABVIEW
Hi everyone,
I am using a FPGA DAQ card PCI 7831R installed internally in my pc. My PC is detecting the card but showing a warning beside the FPGA I/Os of the connector. Hence  I am not able to access the i/o ports of the card in the software. Am also using the  SCB 68 terminal block externally for the card.
Please suggest a way to resolve these warnings.
Looking forward for your response,
Project Associate
(1,162 Views)
It seems that You have installed NI FPGA only You need to install the RIO device drivers to use the i/o's of 7831R..
Kindly verify if you have installed the device drivers or not..
CLD Using LabVIEW since 2013
(1,128 Views)
Accepted by EKANSH_CSIO
i searched for device drivers , I think they are installed and up to date.
(1,106 Views)
Try reinstalling the device derivers of FPGA
(1,101 Views)
