WARNING TDMS memory leak in LV 2010
To be clear the "Always Copy" workaround should only be needed on LabVIEW 2010 and 2011.  I have seen this issue and using Always Copy, or recompiling to LabVIEW 2012 and not having the Always Copy works without a memory issue.
Message 21 of 21
(706 Views)
