WHEN I TRY TO PUBLISH A VI ON THE WEB I GET AN " INVALID IP ADDRESS"?
Hi all
i have this problem while trying to publish a vi on the web. i use the web publishing tool to create the htm file but when i try to view it i get an access denied message. when i go to the www folder and try to open the created htm i see a blank box with the header and footer i have selected, but the frame is empty and after a few seconds i get the message invalid server ip address. i am not sure what is wrong so if anyone has an idea please help.
some details: LV 7, win2000. Also i'm connected to a LAN.
thanks in advance guys
ioannis
Message 1 of 13
(5,273 Views)
Do you run any kind of personal firewall software?
Message 2 of 13
(5,264 Views)
Hey ioannis!
Have you made sure that the Web Server is on?  Here is a KB that describes what seems like your issue.  Repost if not!
Hope this helps!
Andy F.
Message 3 of 13
(5,248 Views)
hello and thanks for the response!
I don't run a firewall on my pc. There is a firewall for the LAN though. Any chance that the firewall is causing the problem?
Thanks again..
Message 4 of 13
(5,237 Views)
for Andy F.
 Thanks for the response!
I am sure that the web server is on, the htm file is in the www folder. i followed every step described in the manual but no progress.
I will keep trying and if anyone has any ideas i will be obliged.
thanks guys!
Message 5 of 13
(5,236 Views)
Well guys i had some progress. i disabled all the ie's proxies and instead of having the "invalid server ip address" message i get "client does not have access to specified VI".
I modified the browser access tab under tools>>options>>... but nothing changed.
Any ideas? thanks in advance for your time.
Message 6 of 13
(5,231 Views)
after a lot of trial and error i managed to publish the vi. From the web publishing tool window i managed to preview the vi and then to see it from the ie. but:
when i close the web publishing window i get an internal server error, when i have it active everything is ok!.
detail: i installed the run time engine on the remote pc. same thing happens when the web publish window is active on the host pc the remote pc is viewing the vi. when the window is closed it gets the internal server error. what is funny is that the remote pc asked for re-installation of the run tim,e engine.
HELP !!!!
Message 7 of 13
(5,229 Views)
Hey ioannis,
So I would recommend starting from scratch on this one and seeing if we can get things to work.  I would recommend following these steps:
  1. Make sure that you have access to port 80, which is what LabVIEW and the Web Server uses for communication.  This might mean turning off virus checkers or firewalls, as Altenbach suggested.
  2. Restart your computer.  This is to make sure that there isn't anything already accessing this port that is conflicting.
  3. Start LabVIEW once the computer is back up.
  4. Open the VI that you would like to publish.  I might recommend using an Example just to test, but you could use your program.
  5. Select Tools » Web Publishing Tool (WPT).
  6. On the bottom of the WPT window, press the Start Web Server button.
  7. Configure your VI as you would like.  You can probably just use the defaults for now.
  8. Select Save to Disk and replace the file if necessary.
  9. Hightlight the address that comes up in the Document URL window and press Ctrl+C to copy it.
  10. Open Internet Explorer and past the URL into the address bar on the development computer.
These steps should be all that is necessary to use the WPT, so please follow them and let me know if they help or not.
Thanks!
Andy F.
Message Edited by Andy F. on 03-17-2006 12:41 PM
Message 8 of 13
(5,211 Views)
hi Andy
Yes the vi is published. i followed your procedure and i had no problem at all.
Thanks for the tips and for your time!!!
ioannis
Message 9 of 13
(5,197 Views)
Can u specify how u make to see it from the ie? I have encountered the same problem as you.
After I used Web Publishing Tool, I can see it from the small preview window. But when i click on " Preview in Browser ", IE said " cannot display the webpage".
If I try to open the source html file directly, the "invalid server ip address" problem still exists.
Anyone can help?
Thank you
Message 10 of 13
(4,587 Views)
