WIth LabVIEW how do I control an instrument with a RS232 output, using a RS232 to USB converter cable.
WIth LabVIEW how do I control an instrument with a RS232 output, using a RS232 to USB converter cable since I dont have rs232 ports. I have two instruments that I want to control in this manner. One is an Imada ZPS force gage with RS232 output. The other is a Panasonic HL-G103-S-J laser micrometer sensor which is RS422. I've done considerable LabVIEW programming using GPIB but I have no experience with devices like these. Any tutorial or examples would be greatly appreciated.
Thanks.
(3,872 Views)
I understand that you want to control a device which having RS 232 port as output. If so, you can use an USB-RS232 cable from PC to device and you can control or monitor the device.
See this link http://zone.ni.com/devzone/cda/epd/p/id/2669
Also, first check the device in hyperterminal and then continue to program in labVIEW. You can find the serial VI's in Instrument I/O.
(3,870 Views)
The article that you referenced only refers to a COM port. I'm using USB ports connected via a USB to RS232 cable. How do I specify the USB port in LabVIEW? Also are special drivers required?
(3,866 Views)
Accepted by chuck72352
When you plug in the USB-RS-232 converter, it installs a driver in Windows that makes it look just like any other RS-232 port.  You may need to install the driver from whatever CD came with the converter.  It will get a Com port number like Com5 depending on what the next available number is.
(3,863 Views)
What is COM port, USB port?
If you plug your USB to PC USB slot them LabVIEW automatically lists the respective COM port for data transfers through USB-your RS-232 device.
(3,861 Views)
