Wait for front panel activity
See if this does it for you.  It uses a notifier to trigger the counting loop to start, and it also uses the notifier as a way to trigger the other loops to stop.  When the user interface loop stops, the notifier is destroyed.  This causes an error when the other loops attempt to access that notifier, and the errors stop the loops.
As for your original problem, it looks to me like you were very close to having it working the way you wanted, but why didn't you simply wire the output of the equals comparison to the while loop stop terminal?  Did I misunderstand what you wanted?
Message 21 of 26
(1,954 Views)
Oh waw! that was just what I wanted, thanks!!! Well I tried to send the true statement to the loops stop button, but couldnt get it working, maybe I messed the case structure up some how 🙂
But finally it works, great!! Just one more question, howcome that you are not allowed to switch the "enable" on and off more than once on the "write to mesurement file"?
Thats why I use a relay to simply cut on and off the data instead, but im not sure it its the right way? 🙂
Message 22 of 26
(1,944 Views)
I don't know.  I took a brief look at the code generated by Write to Measurement file - you can do this by right-clicking on the Express VI and choosing Open Front Panel - but it's more complicated than I have time to investigate right now.  Perhaps someone who's used that VI can answer.
Message 23 of 26
(1,921 Views)
Nathand:
Do you think that I should open a new tread with the "measurement" question?
Message 24 of 26
(1,888 Views)
Nope, I think you should try a search on the forums Smiley Wink
A quick search for "Write to Measurement File" turned up this thread in which it is acknowledged as a bug in LV2009.
Message 25 of 26
(1,886 Views)
Accepted by BjarneDK
Hi Nathand,
Thanks for the link, it was a bug in the VI, but I found a get around :-). Ill try to be better at seaching the forum, next time 😉
Well, I think that I got my questions solved in this tread, thanks to you all especially Hummer1 and Nathand :-).
Message 26 of 26
(1,869 Views)
