Wait on Front Panel Activity crashes labview?
🤐 probably not one of my better habits to be sure, a subtract would be clearer, it just allows you do to a subtract with 'nicer' block placement and wire routing.
Message 41 of 53
(2,035 Views)
Do you have all of your front panel activity captured in an event structure elsewhere in your code? Does this event structure have a timeout? Perhaps it would be more practical to implement code that only ran if the timeout ran x times consecutively. This would be as simple as initializing a shift register to 0. In timeout case if it is less than X then increment - otherwise run your code to turn background scanning back on. In all other cases reset the value to 0. You could add logic in the timeout case to track whether it's on or not, and do nothing if it's already on.
Message 42 of 53
(2,023 Views)
I can't really see why the Wait For Front Panel Activity funtcion would be affecting your application in this way.  I do know that you are using a VI that was created what, twenty, maybe twenty-five years ago to solve a problem that was solved a few years later.
Maybe, as others have mentioned, you might re-architect the code to use a different approach - if nothing else, at least as a troubleshooting step.  All you need to do if it doesn't solve it is revert to the current version in the repository.  (You have one, right?)
Bill
CLD
(Mid-Level minion.)
Message 43 of 53
(2,004 Views)
It feels a bit like we're backtracking here, this has all been covered, chaps.
This is exactly the solution Altenbach suggested in the first reply to this topic. As I said in my reply, alongside the 'Wait on FP' there is an event structure that handles UI interaction, and triggers background reads on timeout.
The issue, as per the linked reply, is that
" ... the timeout case triggers other cases (via signalling property node writes), and those would be indistinguishable from user triggers (unless in every case I added code to check the event source, which would be a fair bit of work). So it's not as easy as counting how many consecutive timeouts occurred."
And yes, I shot myself in the foot by not decoupling UI interaction from code execution - I've admitted that already, but i'll say it again. At this point, though, I'm just not up for restructuring the code.
Since this thread doesn't seem to be going anywhere at this point, I guess I'll put you all off by scaring you with the real code: I uploaded it to github - don't expect to be able to run it without any hardware or dependencies, but at least you can see what i'm working with here.
I really don't see why the age of the function is in any way relevant. If it works, it works. If it's broken, it should be fixed or removed.
As some excuse for my unwillingness to put in the time and effort of a rewrite, I'm currently working a 9-5 writing firmware, writing up my PhD thesis in the evenings, and preparing for a post-doc interview next week. So to say I've got a bit much on my plate I feel is justified. 😫
Message 44 of 53
(1,993 Views)
Accepted by msoflaherty
Alright, new version:no Wait on Front Panel Activity, just the sleek, modern Event Structure.
Timeout of course flips the controls. Then I need an event to handle all possible user interactions, in which I do nothing. I've attached that case to 'This Vi: Key Down', and a 'Mouse Down' event for each front panel pane on my FP (not sure why there's no global one, but oh well).
I found I also needed to add a value change event for the Stop button; simply checking the state of the control wasn't working, evidently the first UI activity event triggers before the new value takes.
Fingers crossed, this one won't crash!
Message 45 of 53
(1,984 Views)
Sorry for the backtracking. For some reason I had forgotten that you were using value signalling in your timeout - I thought that you were using User Events in which case you could easily decouple anything that was still coupled.
I get 404 error when I click on your github link. Is it possible that you could zip the files and upload them here? I think that seeing your code would give better clarity.
Good luck on the PhD thesis and the interview!
Message 46 of 53
(1,942 Views)
Thanks for the luck, i'm going to need it!
I must admit I had second thoughts about uploading the code, but it was too late to remove it from my post, so... perhaps it's best to just use your imagination. 🙃
We'll see whether the event structure replacement works - so far, no glitches... 🤞
Message 47 of 53
(1,932 Views)
Quick update, it's now over 4 days since swapping out the 'Wait on FP Activity' block with an event structure attached to 'Key Down' and 'Mouse Down' on all panels, and so far no issuess. 😊 The last attempt with 'Wait on FP' died after 23 hours, so this is already a few times over that mark. No other changes, no hardware or software added, removed, changed, just that one block diagram swap. Anyone still not convinced? 😉
Message 48 of 53
(1,880 Views)
Cross your fingers!  Hopefully this means you can get back to the important stuff.  🙂
Bill
CLD
(Mid-Level minion.)
Message 49 of 53
(1,860 Views)
OK, it's been nearly a week, I'm going to mark that as the solution.
This is the new code:
case [0] is shown
case [1] stops on stop.
case [2] stops on stop. (those 2 cases need to be separate as only this one seems to catch the new value of the stop button).
This still feels like a bit of a 'hack' to me - using an event structure with events registered to 'key down + mouse down panel 1 + mouse down panel 2 + ...' seems like an inelegant way to reproduce exactly what 'wait on FP activity' does natively. But, it works, so good enough for me.
Thanks to altenbach, john, bert, ben and bilko for all the suggestions and support. 😁 You guys make these some of the best forums around.
Message 50 of 53
(1,829 Views)
