Wait untill button is pressed
Is there any function available in LabVIEW which pause the execution untill the button is pressed?
I mean at a stage, i need my program to wait untill the button is pressed, so is there any function available to achieve this.
Kindly guide.
Regards
Message 1 of 11
(10,683 Views)
Use an Event Structure with only a case for the button you want to press. Wire this in the path of your execution, for example using the error wire. You don't need to do anything in the structure.
GCentral
Message 2 of 11
(10,680 Views)
Something like this?
Message 3 of 11
(10,630 Views)
I usually just do this:
=== Engineer Ambiguously ===
Message 4 of 11
(10,611 Views)
I meant something like this.
GCentral
Message 5 of 11
(10,605 Views)
I do that as well but make sure the "Lock FP ..." option is NOT selected in that event case. If they hit the button twice the FP will lock-up.
Ben
Message 6 of 11
(10,593 Views)
What you need is a state machine. One state waits for button presses.
Message 7 of 11
(10,583 Views)
Message 8 of 11
(10,553 Views)
@paul_cardinale wrote:
That would misfire nearly 100% of  the time. assuming there are other controls on the front panel. Also, are you sure that the button state is read after the activity is detected. Most likely you read the stale state from when the loop started.
Message 9 of 11
(10,544 Views)
It works fine.  I've used it many times.
Message 10 of 11
(10,531 Views)
