Want to bring my vi from 2010 to 2011
We have just finished creating a vi that will be used in student labs where I work. It was created in LV 2010 and when I try to open it on my computer in LV 2010, it opens fine and loads all of the necessary vis to run. This is a pretty simple program that uses a USB A/D system and collects data on 1 or 2 channels and then saves it in Excel after showing it realtime.
I just received LV 2011 and decided that I should run this in 2011 and then make it an EXE file to install and be up to date with what LB I am using. When I try to open this vi in 2011, I needs approx 10 vis that it can't find. These are standard LV vis that are in the standard install of 2010 but don't seem to be in 2011.
How do I go about "importing" this vi to 2011? I did find a few of the necessary vis but they are buried everywhere so it will take som time to find them all. Is there an automatic way to do this?
Dave
(2,181 Views)
What VI's does it say you are missing?
You say they are "standard LV VI's".  But could they be part of a driver set or toolkit you didn't install with LV 2011?
(2,177 Views)
