Error using Matlab Node
Please help.  I am getting a couple errors using the Matlab script node in my.vi file.
1) First, I am getting an error message telling me to use fopen to generate a valid file identifier.  I am able to bypass this with by removing the semicolon after the first line of the script, as shown below.  Although I do not understand why this works.
2) With the semicolon removed, I am now getting an error message stating I have an undefined function or variable 'Y'.  I am completely stumped.  Please help!
(3,719 Views)
The 'X' should not be enclosed in single quotes. You are passing in a string, and this is what you want the first parameter. As you have it, the filename is "X".
I have no idea about the error with Y. I can enter a simple Y=max(0,2) and have a Y output and it works just fine. What version of LabVIEW are you using, and what version of Matlab are you using.
(3,715 Views)
I am using Labview Version 10 and Matlab 2009b.
(3,705 Views)
OK... Did you make the correction I mentioned?
(3,703 Views)
Yes, I still the get same error:  'undefined function or variable Y'
(3,701 Views)
Hello krang,
Have you been able to get a simple function working correctly using the Matlab Script?  For example, can you try just feeding it a numeric constant x, do a simple y = 4+x then grabbing y?
David A.
(3,683 Views)
