Want to count number of times "1" comes in digital signal.
I am using USB 6210 I/O and want to count the pulses in my digital signal generated by gear tooth sensor. I have integrated the whie loop within the case structure. Firstly case structure identifies the "1" value in digital signal and starts incrementing the local variable. The While loop I used is to increment  once only when single pulse comes. if i remove the while loop then it increments the local variable continously till next zero comes(in a single pulse).
But even after having while loop within the case structure and changing the while loop stop condition to "stop if true", the program stuck in the while loop.
Can anybody tell me how to do this ?
Message 1 of 10
(4,272 Views)
Can you show us the code that you have developed. It must be a simple logic to count when you use the shift register.
Message 2 of 10
(4,270 Views)
Check this VI.
I took 1000 sample n after that calculated  for Each Signal "1"s. If Yes add +1 else No.
Munna
Message 3 of 10
(4,242 Views)
Please find attached zip file, it should help you. its developed in LabVIEW 2010.
Miraz....
Kudos is better option to thank somebody on this forum.Smiley Wink
With Regards
Miraz
Message 4 of 10
(4,229 Views)
The Boolean Crossing PtByPt is perfect for this
Message 5 of 10
(4,207 Views)
@Indiano wrote:
I am using USB 6210 I/O and want to count the pulses in my digital signal generated by gear tooth sensor...
You should really just use one of the hardware counters for this.
Best Regards,
John Passiak
Message 6 of 10
(4,187 Views)
Thanks. But i had applied some digital logic in my code and it is working for me nicely.
With Regards,
Indiano
Message 7 of 10
(4,150 Views)
You are right, but fortunetly i have applied some digital logic with shift registers.
Anyway, Thanks.
Message 8 of 10
(4,147 Views)
If anyone in this thread helped you, feel free to give some kudos.  It looks like several good developers came up with some helpful ideas and they deserve some thanks.
Message 9 of 10
(4,118 Views)
Anyway, Thanks.
Fair enough, but doing it this way will ultimately limit how fast of a signal you can measure (might not be an issue for you).
Best Regards,
John Passiak
Message 10 of 10
(4,104 Views)
