Want to load data from last 2 months, from a .txt-file into a table
Message 11 of 15
(845 Views)
Here is 8.0 Version
Tim
GHSP
Message 12 of 15
(832 Views)
Hi Jean-Marc  I just simulated your schematic.But there is a thing, all the data is coming in the array, not only the data of the last 2 months.And the second thing is that it has to look a bit better.An array is not so nice, by my opinion. I attached my own version to this post so you can look how I like to have it.In the "Base Directory"VI you can fill in the Base Directory and Source Directory. Is it possible to make some changes and work with my own version?I'm just at the beginning working with Labview so it is sometimes difficult for me. Greets
Message 13 of 15
(820 Views)
Why you don't starts with the example from aeastet - his example is better than mine?  You just have to replace the 2D array by your own table and add the file path.
JM
Message Edited by J-M on 12-10-2009 12:05 PM
Message 14 of 15
(814 Views)
Actually all you should have to do is set the date limits and hit go. It will prompt you for the file path to the file. and based on your limits will get the data that you need.
Tim
GHSP
Message 15 of 15
(804 Views)
