Warning 1073094668 occurred at NI-CAN ReadMult Network Interface Object (ncReadNetMult.vi)
Hi all,
I am working with CAN with our tester,, after receving CAN message from DUT the tester popup this error,, can anyone please tell for this what was the resion
Thank you
(2,851 Views)
Hi , The reason why you would be seeing this error code is due to lack of proper termination of your CAN bus. Terminating resistors are required to ensure proper communication on the CAN bus.The KnowledgeBase articles linked below contain more information about termination requirements for both High and Low-Speed CAN. http://digital.ni.com/public.nsf/allkb/B8671A347DCBBBA486256F2D005D19A0?OpenDocument Thanks Pranchal National Instruments
(2,825 Views)
