fixed exe form
hi all,
my labview project just contain few button and text box in control panel. after i making it in exe file, and running the exe file, i found that if i maximize the exe windows, there will be many empty place at the side. so i plan to fixed the size of exe form. how to do that?
(3,391 Views)
control panel means are you referring to front panel?
There are a lot of threads discussing about this.
see here
Post if any problems you face further
(3,386 Views)
Well, then don't maximize the exe window. 😄
You can specify if the windows can be resized or not. This is part of the window apperance of the VI properties. Once you built the executable with this setting, you will not be able to resize the window while the executable is running. So make sure it is set to "run when openend". As an application, it should always be running.
(3,383 Views)
yeah...got it. thanks everybody...
(3,349 Views)
