Watlow Ramping Issues
Is there any updates via GPIB? That is all we have on all of our controllers
Message 11 of 14
(1,006 Views)
Sorry, their is no firmware upgrade using GPIB.
Message 12 of 14
(1,003 Views)
The f4 (at least ours) are serial and we use a GPIB to Serial box from ICS http://www.icselect.com/
Might be worth a peak inside to see if you can bypass the GPIB and to directly to the f4 serial interface
=== Engineer Ambiguously ===
Message 13 of 14
(996 Views)
To perform the upgrade, a computer with RS-232 is needed; and then these three connections connection into terminals 14, 15, 16 on the F4. 14 is the transmit, 15 is the recieve, & 16 is the common.  Here is the link to the F4 manual, and then reference page 12.10 for RS-232 wiring.  http://www.watlow.com/downloads/en/manuals/f4sd_eng_g.pdf
Message 14 of 14
(991 Views)
