Waveform Chart Properties bug
I'm using LabVIEW 2017. When I set some Chart XScale properties, I see the changes reflected on the chart. If I then make the chart invisible and then visible again, my change is gone. I've attached a snippet (I think so anyway - I've never used snippets before). If you run that code with HighLight execution on, watch the chart X scale change as expected, but then change back at the end unexpectedly. Can anyone explain this behavior??
Message 1 of 8
(3,791 Views)
Sorry, cannot test in 2017, but in LabVIEW 2018, everything seem to work fine with your snippet.
(be aware that once you add data to the chart, things might roll later once the history buffer is filled)
Message 2 of 8
(3,787 Views)
In no one tests it in 2017, maybe you could make a video of it?
Certified LabVIEW Architect
Message 3 of 8
(3,749 Views)
Just tested in 2017 (32 bit).  Works like I would expect.  I don't see any problem.
Message 4 of 8
(3,734 Views)
How do snippets to work?
I have tried three different browsers (Chrome, Firefox, IE) and either end up with the image in the block diagram of just a link to the image in the block diagram.
=== Engineer Ambiguously ===
Message 5 of 8
(3,723 Views)
Save the image to your local computer, then drag it to an empty BD.
Message 6 of 8
(3,719 Views)
Or refer to this post by Hooovah
Message 7 of 8
(3,691 Views)
No problem with version 17.0 (32bit)…
Message 8 of 8
(3,682 Views)
