Waveform Graph X Scale Format
I have a graph currently display time in relative time in the pre-defined format HH:MM:SS. I would like to display milliseconds also if possible. Is there a format available or do I have to create my own?
(2,719 Views)
You can set the X scale format to be just about anything.  Right click on the scale, select properties, then go to the Display Format tab.  Select your X axis in the top-left combobox, then set the format to whatever you want.
(2,711 Views)
