Waveform NI_ChannelName as string
When using the GetWaveformAttributes vi specifying "NI_ChannelName", the returned value is a variant.  Thus, it can't be passed to routines that expect a string channel name.
I can't find a way to convert the Variant to String.
There must be a way to get the channel name as a text string!
Message 1 of 10
(5,958 Views)
Varient to data will do the trick.  Search for it from the functions palette.  (It is located in several places in LabVIEW 7.x and in a totally different one in LabVIEW 8.0).  I think you can also use format into string.
Hope that this helps,
Bob Young
Message 2 of 10
(5,955 Views)
Thanks, that did it.  I had tried several other methods but all gave junk.  I didn't find this because I looked in String functions and Waveform functions.... not in Clusters!
Message 3 of 10
(5,951 Views)
I'm having the same issue, but when I wire a string to variant type, I get an error "datatype of the variant is not compatible with the data type wired to the type input"
I'm trying to extract the waveform name from the attributes and having little luck, any suggestions?
Message 4 of 10
(5,526 Views)
Hi Dude,
have you tried to wire an (empty) string to the type ("default value") input of GetWaveformAttribute?
Message 5 of 10
(5,518 Views)
I figured it out, just have to do it as a two step process, like this.
Thanks.
Message 6 of 10
(5,513 Views)
Hi dude,
using my comment it would be a one step process…
Message 7 of 10
(5,501 Views)
can you provide an example?
Message 8 of 10
(5,497 Views)
Hi dude,
one step:
Message 9 of 10
(5,474 Views)
Could have sworn I tried that and was getting error?!?!?! Anywho, thanks for the suggestion.
Message 10 of 10
(5,437 Views)
