Showing results forĀ
Search instead forĀ
Did you mean:Ā
Waveform conversion
I'm currently doing a project on ECG. I got some raw data and i was told : 1) Open the textfile and display (completed). Now the 2nd task is to convert the data from the file i open to waveform. The data is attached at the bottom. (data was extract from http://www.physionet.org/cgi-bin/chart?database=aftdb&record=learning-set/n01&annotator=qrs&tstart=0... then click to "convert signal to text on the right hand side of the screen) I got some doubts: 1. How the data must be save in order to allow it appear in waveform? 2. from the VI i done so far, i not sure how to continue to do conversion to waveform.
i'm using Ver 8.2 student ver labview
Advice and example are needed for beginner like me.
Thank you
Message 1 of 9
(5,483 Views)
Hi scartch,
see the changed attachment. It's a rather easy job with Labview...Smiley Very Happy
Message 2 of 9
(5,461 Views)
Thanks GerdW. What a great example!
Amanda Howard
Americas Services and Support Recruiting Manager
Message 3 of 9
(5,441 Views)
how do i give rating? help me? Thank alot..
Message 4 of 9
(5,409 Views)
As a tip to the poster: You can also do the file reading with the Read From Spreadsheet File to create the 2D array of numbers:
Message Edited by smercurio_fc on 12-24-2007 02:26 PM
Message 5 of 9
(5,393 Views)
Hi scartch,
If you are logged into the Forum and are able to rate messages, there will be a scale at the bottom of each message for you to do so.  This isn't an option for everyone, but please do rate responses when you are able.  It's always nice to get feedback from others.
Jennifer R.
Applications Engineer
Message 6 of 9
(5,344 Views)
I am stuck ! I cant find the bar u told me to gif rating..Smiley Sad
Message 7 of 9
(5,332 Views)
Hi scratch and smercurio,
@scratch:
Not everyone is able to rate - you have to have a minimum number of contributions to the forum to be able to rate!
@smercurio:
When there's a header in the spreadsheet file you have to read the header first, just using "read spreadsheet file" may give wrong data in the 2D array!
Message 8 of 9
(5,311 Views)
That's what the Array Subset is doing. I saw there was a header, but it seemed to be irrelevant in what was being done. It certainly wasn't being used for the graphing. Therefore, the Read From Spreadsheet File could be used, and you could just chop off the rows that were the header.
Message 9 of 9
(5,304 Views)
