Waveform data (double) to display in Waveform graph
Tktds7kGetWaveform.vi returns values in this format untitled.PNG. I need to find the envelope of the waveform and i require that input to be in this form untitled1.PNG.
So how to get untitled1.PNG from untitled.PNG.
Mathan
(5,247 Views)
Use the operators found on the Wavform palette. The Waveform acts just like a normal cluster with the cateat that you can't edit it. The array of doubles gets inserted as the "Y" array. If you have a start time the "t0" will accept the time. If you have more than one value in the array of doubles then the spacing of the plotted points will be dictated by the "dt" value you specifiy.
Is that enough to get you started?
As always ask followups and I'll try to help out.
Ben
(5,242 Views)
You could use Bundle Waveform components to combine the Y array with the dt and T0 appropriate for your waveform.
(5,241 Views)
This is what my tektronix oscilloscope returns. "Points" returns the output and it is untitled.PNG. How to build this into untitled1.PNG for further processing.
Mathan
(5,231 Views)
Accepted by Mathan
Just guessing...
Wire up the build from your sub-VI (?) using the Xincrement to define the "dt" and the points get wired to the Y array.
Ben
(5,223 Views)
Thanks Ben,
Am trying this with all the possibilities. Will post the findings tomorrow. Thanks a lot for your wonderful support. Smiley Happy
Mathan
(5,209 Views)
