Waveform graph time scale from DAQmx Waveform data
I have an application where i'm pulling AI data from a process, using a waveform output.  At first i only was interested in (4) channels and everything was perfect, the X axis was in seconds, the trends represented the channels...i used the luster unbundle function to separate the channels.
The problem now is that i added and additional (4) channels making my total channel count now (8).  The waveform chart no long works when i unbundle (8) channels of data.  Why?
Basically what i have now is running the waveform straight to the chart, X axis is OLE time and looks bad.
Any help would be appreciated.
THanks
Message 1 of 10
(5,068 Views)
show your code example
Message 2 of 10
(5,057 Views)
4channel.PNGFor (4) channels this works like a champ.  IF i add channels, to the DAQ and to the bundle (sorry i said unbundle earlier) it doesn't like that.
Message 3 of 10
(5,052 Views)
How you collect 8 channels?
Are you sure there presents all 8 channels?
Message 4 of 10
(5,044 Views)
The channels are captured via DAQmx READ.vi, i know they are collecting because i can wire a waveform chart to the output line and get a data on all line.  The time aspect of it is not good though, i would rather use the t0 second counter but what is being displayed is the timestamp.
Message 5 of 10
(5,039 Views)
Show your broken code.
I get single point for each channel form DAQ? Or array of points (waveform)?
Message 6 of 10
(5,033 Views)
Message 7 of 10
(5,027 Views)
why youuse waveform for single element?
Message 8 of 10
(5,015 Views)
This is not helping...
Message 9 of 10
(4,996 Views)
Why not?
on chart you'll see last point only, without history.
And why you want draw clester of WF, not array if WF?
Take subarray of your data and send it to chart
Message 10 of 10
(4,993 Views)
