Waveform peak detector - how to store all the peak locations
Hi RavensFan,
Is it possible you help me to modify my VI?
Message 11 of 16
(918 Views)
See attached.
Message 12 of 16
(904 Views)
Did you see the location displays are the same results as mine. They are not updated!
Message 13 of 16
(898 Views)
I fixed your numbers not changing problem.  I didn't work with the rest of the code where you are taking sections of your waveform.  Or repeating the calculations on the same file over and over again.
Message 14 of 16
(892 Views)
Hi RavensFan,
1.jpgthis is the problem I faced. It can detect the peaks but every the location didnt display beyong 3 second. I have attached the data file on my previous post. You may use that data to try! Thanks
Message 15 of 16
(884 Views)
The waveform graph X display does not matter at all. I only need the function capture the real time of each peak of the signal.
Message 16 of 16
(880 Views)
