Wavefrom graph time from .csv file
You are doing it all wrong then if you want the x axis to have the same values as what is in the file. Instead of writing to a waveform which sets the t0 to 0, do not convert to a waveform and instead write to the offset and mulitplier properties. The offset is going to be the first time and the multiplier is the same dt that you are calculating now.
Message 11 of 25
(1,881 Views)
Hi Dennis
Do you mean something like that :)?
Best regards
Oesen
Message 12 of 25
(1,877 Views)
Yes. Does it display how you want now? You probably have to change the x-axis to floating point.
Message 13 of 25
(1,875 Views)
No 😞
Best regards
Oesen
Message 14 of 25
(1,868 Views)
So what did you set the number of significant digits to? Post your latest VI.
Message 15 of 25
(1,857 Views)
Hi Dennis
Here is my latest VI 🙂
Best regards
Oesen
Message 16 of 25
(1,853 Views)
Thanks. I don't have my laptop right now so I can't look at it until tomorrow.
Message 17 of 25
(1,843 Views)
Hi Oesen
Try this VI, it looks right on my machine.
Changed the offset to be on the X-axis and not the Y-axis, and turned the offset on the y-axis back to 0.
And changed the format on the x-axis graph to display 1 significant digit.
Best Regards
Anders Rohde
National Instruments Denmark
Message 18 of 25
(1,832 Views)
Hi Anders.
Can you please upload your VI as a 2010 version og LabVIEW
I have tried your procedure, but my y-axis values is crap this time :(.
Best regards
Oesen
Message 19 of 25
(1,823 Views)
Try the attached, 2010 version.
Best Regards
Anders Rohde
National Instrumnets Denmark
Message 20 of 25
(1,821 Views)
