Wavefrom graph time from .csv file
Thank you very much Anders ! 🙂
Can i change the x-axis offset to always be the second row of the first column ?. I will get rid of changing the offset everytime my time value changes.
Best regards
Oesen
Message 21 of 25
(818 Views)
This is really basic stuff. You are already indexing the start time from the file. Just wire it up, please.
Message 22 of 25
(815 Views)
Thanks for the answer Dennis
I have to use a array function in the array palette to perform this ?
Best regards
Oesen
Message 23 of 25
(810 Views)
Please, you already have all of the functions you need. Look at the code. Turn on Context Help if it's not on. Probe the output of the Index Array function - the one where you are taking the values from row 0 and row 1. The first element out has a value of of .84, correct? Now do you understand when I say you just have to wire this to the property node instead of the constant?
Message 24 of 25
(806 Views)
I got it now. Thanks for the help 🙂
Best regards
Oesen
Message 25 of 25
(802 Views)
