Way to select just control, not label or caption (for alignment)?
Is there a way to select just the control portion of a control or indicator, and not the label or caption?  When I am aligning multiple controls (especially if they are different styles),  I find I have to shut off the Labels or captions to get the vertical alignment command to work properly, then turn them back on.......
I would like it to move the label or caption, just not take it into consideration when doing the alignment.  It must be using the bounding box to calculate the alignments?
Message 1 of 9
(4,035 Views)
As far as I know that is the only way to align them.  But one of the Guru's might have a trick up their sleeve.
Message 2 of 9
(4,025 Views)
I don't think there is a simple way, because there is a hierarchy. You can align the labels seperately, but you cannot align only the controls. This is probably good.
You should simply ensure that the labels are aligned with one of the edges of the control, for example most of my labels are right-aligned with the control. If you now align multiple such controls, also do a right-align and the labels will not interfere.
Message 3 of 9
(4,006 Views)
I agree with Altenbach, but if you do want to this, you can. Here's a basic example.
___________________
Try to take over the world!
Message 4 of 9
(4,000 Views)
Yes, as I said "I don't think there is an easy way".
Cool VI though. 😄
Message 5 of 9
(3,987 Views)
Ok, now you're just showing off......Smiley Very Happy
Thanks!
Message 6 of 9
(3,982 Views)
Cool concept!
I use the 'alignment code' in a case structure set to not execute (LV 7.1) instead of reference, because I that were more specific cases I used that. But one more general case is the 'SetWidth' of a ListBox for equal width of all coloumns...
Felix
Message 7 of 9
(3,962 Views)
Actually, the point was that this can be converted into a usable tool if you really need it. It would just require some work.
___________________
Message 8 of 9
(3,958 Views)
So cool tst ! Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 9 of 9
(3,932 Views)
