Ways to increase the font of cursors on a xy chart or a new way to display information on a chart
Hello!
There is a problem.
There are 12 cursors in the program. No. 0/2/4/6/8/10 are used to display the calculation of the integral value (this is the area under the curve, bounded on both sides by cursors).
The problem is that I cannot change the font in any way - change the size, style, etc.
Tried it through the annotation list and it doesn't work.
Are there any other options? Has anyone solved a similar problem?
 I will be very grateful. Thank you so much.
(2,043 Views)
Have you tried to use Tools Palette in View>Tools Palette
I think it will help you.
Best regards.
(1,989 Views)
Yes, I tried it.
The calculation window changes, but the cursor's font size remains the same.
(1,984 Views)
Thanks, I will try.
(1,955 Views)
