Web Publishing can't display image
I am trying to use the web publishing tool to view a VI. I have tried the snapshot option and the monitor option and when I view the html file on the same computer, the image won't display. I have the 2012 Base edition so I'm not sure what options I can use. It works on neither Firefox or Internet Explorer. What am I doing wrong here? Thanks.
(2,375 Views)
Hi awolfedais,
There are a couple of things that you can try to make this work. First off try doing a quick mass compile of the program. Tools<<Advanced<<Mass Compile... If you are using Restful Web Services try rebuilding and redeploying. If neither of these work take a look at this article. There may be something that is keeping you from displaying that particular component since it is an indicator. You could try using the embeded option. You can also double check your settings under Tools<<Options<<Web Server and reset to default unless you have specific settings you need. There are other web publishing options as well if none of this seems to work. Let me know if this helps and if you have any questions.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/project/webpublishingtool.html
Ryan
(2,346 Views)
