Web Server Configuration
Hi
I have tried to configure and start NI Web Server but i'm getting the below error
"Could not find a part of the path 'C:\ProgramData\National Instruments\Web Server\logs\startup.log'.. "
Then, I tried to create the above path manually and restart the server. but it says "The web server failed to start."
I could see that a file from this ('C:\ProgramData\National Instruments\Web Server\config\summary.json.tmp'.) path is not found.
I have attached the screenshots of the errors i'm getting. Could you please help me out in configuring with it?
Thanks and Regards
Suneel
(2,864 Views)
Hi Suneel,
I can see that it's been a while since your original query - can you confirm if you are still stuck with this error?
Akshay
(2,741 Views)
