Web Service Problem: "Couldn't connect to server"
I have been using the Web Services in some LabVIEW Projects, and everything was working fine in the Development mode and Executable mode. I was publishing a Web Service and redeploying it as usual, when I was confronted with this Error Message: "Couldn't connect to server".
Even I tried publishing the "WeatherMonitor" example and it showed the same error message:
I checked further the Web Service Configuration settings and Previously it used to show all the published Web Services as below:2.PNG
However, now it's only displaying the following error message, which means:
"The Webservice API key cannot be acquired from server. Make sure, that the server is online or that your User account has the "GetWAPIKey" authorization" 3.PNG
I want to understand what would be the possible remedies for such a problem.
I don't know if something would have been blocked by the IT or from a Firewall??!
Thanks in advance,
Ahmed
(4,689 Views)
Hi Ahmed,
This looks indeed like some IT issue with user groups and set group-wide permission. Please, verify with them if GetWSAPIKey permission is anyhow blocked in your local network.
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(4,622 Views)
I also meet this problem? Could you please help to tell me more details and advice?
(4,335 Views)
Has your problem been resolved now?
Could you tell me how it is resolved? Thanks very much!
(4,333 Views)
I have the same problem, everything worked fine and suddenly I stop connecting to the server. Can someone give me information on how to solve it?
(3,545 Views)
I know this is a little old thread. I am just posting it to letting other know how it is solved it for me. May be helpful for someone.
I have encountered this problem today. I have repaired web server, labview, worked with services, nothing solved my problem.
Then I have added my local user account name in the security configuration tab as admin. Then it instantly solved this issue.
Hope this helps.
Best Regards,
Muruganandhan S,
ISTQB Certified Test Automation Engineer
(3,162 Views)
I had this problem with trying to manage the Application Web Server for a compactRIO via web browser (Microsoft Edge). The fix was to unpublish the webpage and republish it.
(2,528 Views)
