Web publishing Tool. Does not show front panel on EI on other computer.
I am trying to access VI from other computers using IE. After set up my VI for web publishing, I tried view the VI from other computer using IE but from panel doet now show. I think I am accessing the VI since I can see text but not front panel. Thanks
(2,664 Views)
Did you install the LabVIEW run-time engine on the other computer? You have to do this first.
(2,657 Views)
Thanks. It work now. But does this only work in LAN? What do I need to view the front panel from, let say, home?
(2,647 Views)
If your company LAN is behind a firewall, you'll need your IS department to open a port for you.
(2,639 Views)
