Weird network stream broken wire
Well, we decided to use network streams. Here is a strange one. Can anyone explain this one to me? I have resorted to transposing the data external to the process that receives it so a transpose doesn't have to be done in the receiver, which is resulting in a broken run arrow.
Full disclosure, this project we are required to use LabVIEW 2011, haven't tested in newer versions.
Message 1 of 12
(5,768 Views)
Seems to work in 2013.  I know that doesn't help any, but at least you know.
Message 2 of 12
(5,753 Views)
LV11 SP1
Message 3 of 12
(5,750 Views)
Darin, note the VI is different (subtle icon difference). I am using write multiple. I should have been more clear, and thought that while posting but forgot to mention it.
Message 4 of 12
(5,730 Views)
This is a bug that was fixed in LabVIEW 2012.
Message 5 of 12
(5,720 Views)
Accepted by GregFreeman
Message 6 of 12
(5,695 Views)
And once again, the Always Copy comes to the rescue when you need a work around.
Message 7 of 12
(5,679 Views)
HAHAAH I just noticed your tags Darin. Well played.
Message 8 of 12
(5,616 Views)
Be that as it may, the tags weren't placed there by me.
Message 9 of 12
(5,602 Views)
Ah, it does say "everyone else's" tags.
Message 10 of 12
(5,593 Views)
