What am I doing wrong with asynchronous call and forget?
@mcduff wrote:
Mine stays yellow, right click and then you see the option.
Worked in 2024Q1 as well.
To bring information back from the thread in the 2024 Beta board, I was still getting the freeze if a menu was open.  I'm concluding that Weibe has not installed the patch yet which had a fix for the run-time type propagation.  Him not seeing the freeze appears to be an artifact of that bug.  So one bug squashed, but another, smaller one, instantly takes its place.
Using the secret ini token and enabling the "run in any thread" option fixed the freeze issue for me.  I'm lucky I have yet to run into the situation which would cause this, probably because I would be launching these clones at initialization, likely with no GUI visible.
Message 21 of 34
(1,342 Views)
Yes, no patch yet. Too bad it stopped working.
The key isn't really a convenient option, unless I can set it at run time. If not, a check in check out could change functionality.
Message 22 of 34
(1,330 Views)
@mcduff wrote:
wiebe@CARYA wrote:.
Also keep in mind that Open VI Reference needs the root loop to be free when opening a strict VI.
There is an INI token you can change and have the option of running at any loop. See https://lavag.org/topic/23800-dynamic-calling/?do=findComment&comment=173305
The Open VI Reference will block on UI Rootloop even in the first (top) one.
This gave me an idea how to "block" Call & Forget. If inside of the called VI something will block UI thread for the long time (for example, DLL called in UI Thread and stays inside - for example, its sufficient to call Sleep for few seconds from kernel32.dll), then in second iteration the main loop will be definitively blocked.
Message 23 of 34
(1,305 Views)
@mcduff wrote:
wiebe@CARYA wrote:.
The semi-official Ni statement is to not use it and stop telling about it.
Go fish.
Dynamic VIs are simply not a production ready technology.
To be honest, in 95% of the use cases, it can be done better without VI Server. Sadly, the remaining 5% is a problem.
Message 24 of 34
(1,260 Views)
Curious. Would you mind giving some examples where it is used incorrectly?
Message 25 of 34
(1,244 Views)
It's not so much incorrect (there are no rules), it's that there are consequences. Consequences that can be avoided.
Anywhere you use Open VI Reference (strict) or the Run VI method, while the user can trigger a menu, popup (messagebox, file dialog), resize a FP, you could have a problem you don't even know about. Because if any of those things happen (in any VI), the root loop is blocked for Open VI Reference (strict) and Run VI method.
In general, dynamic VIs make things more complicated. More complicated than a simple SubVI that's running, and stops running if the caller stops.
There's for instance the problem where clones keep running, and there's no (decent) way to get their references if you lost them.
Dynamic VI references are only unavoidable if you have an unknown number of things to start or unknown objects to start (like plugins). Any other situation you don't have to use VI Server to get run time functionality.
However, it might be convenient to start something dynamically to get edit time advantages. For instance, so you can stop code independently of the rest.
Message 26 of 34
(1,244 Views)
@Andrey_Dmitriev wrote:
Oh, sorry, I was busy with gif creation, didn't catch this, should refresh comments before posting
That's quite useful, how did you create it?
Qestit Systems
Certified-LabVIEW-Developer
Message 27 of 34
(1,144 Views)
Using ScreenToGif (https://www.screentogif.com😞
Message 28 of 34
(1,140 Views)
I use ScreenToGif too. It's very easy to use.
Message 29 of 34
(1,128 Views)
Nice tool! I've always used OBS to do that, what a pain for such a simple task 😅.
Message 30 of 34
(1,114 Views)
