What am I doing wrong with my code?
Hi noob,
BuildArray, feedback node and NOT...
Message 11 of 13
(1,097 Views)
Accepted by LabNoob14
1D array boolean to a sink that is also boolean gives me broken wires?Now This.PNG"FUEL WEIGHT" is just an indicator
Disregard this post I added a 0 into the "type" input of the FP and it fixed the broken wires...
Message 12 of 13
(1,084 Views)
Because now you are operating on a array instead of a scalar as before. If you want to trigger if at least one of the elements matches the condition, insert an "OR array elements" right after the comparison.
Also, since now all inputs to "built array" are 1D arrays, you want to set it to concatenate mode (right-click...) to make one longer 1D array.
Message 13 of 13
(1,080 Views)
