What architecture for my application?
Could you please post a small example VI about how to share a queue between a master VI (message generating loop, e.g. my program logic) and the slave VI (message handling loop)?
You said you store your queues in action engines, but I'm not exactly sure what that means.
Basically I need a reference to my queue, so that the master VI enqueues an element, the slave VI knows that the queue has this new element.
Message 11 of 14
(915 Views)
My rough guess would be to take the example and create subVIs out of each loop.
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(903 Views)
Indeed that works. I just obtained the queue using the correct name, no explicit reference function needed. Didn't know that would work 🙂
Message 13 of 14
(893 Views)
If you have named queues that works. I usually have a Queue ref input and wire it directly. Both are good and valid.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 14
(878 Views)
