What are the parameters and outputs of the activex methods relating to motor control?
Never mind, silly me. All documentation is included with the program. Open up Programs -> Thorlabs -> APT -> APT Server -> APT Server help file
In it navigate Programming Guide -> motor control -> Motor Control methods.
Message 11 of 13
(1,086 Views)
I was having the same trouble locating any of the aptserver help files. However, I found the compiled HTML file in the files that were downloaded on install, and i think this is the reference you (and I) were looking for!
File path: C:\Program Files (x86)\Thorlabs\APT\APT Server
The HTML compiled help file named "APT Server" should give you the correct help menu that describes the methods. hope this helps!
Message 12 of 13
(828 Views)
I apologize for not reading the complete thread before posting... clearly you already found this solution!
Message 13 of 13
(827 Views)
