What contourc function returns
This question is actually about Matlab, but the thing is I don't really use Matlab; Matlab is simply a labor for LabVIEW in the code.
In Matlab, there is a function called c=contourc(im,[.8 .8]). This function is supposed to return a single contour at level 0.8. The return is a 2X387 matrix in this case. Can someone tell me what this matrix is? It does not look like a collection of pixle positions.
Is there an efficient Matlab forum like this NI forum somewhere?
Message 1 of 8
(6,035 Views)
Perhaps this Mathworks forum is what you're looking for:  http://www.mathworks.com/matlabcentral/answers/
James McNicol
Applications Engineer
James M. | Applications Engineer | National Instruments
Message 2 of 8
(6,024 Views)
James,
Is there similar function in LabVIEW? I am trying to convert a m code into LV. Thanks.
Message 3 of 8
(6,015 Views)
Accepted by MengHuiHanTang
Hi Meng Hui,
I'm not sure of the exact purpose of that Matlab function, but is this close to what you're looking to do?
https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/imaq_extract_contour....
James McNicol
Message 4 of 8
(5,991 Views)
Thanks, James.
That matlab function is used to return a contour, but I guess the difference is that the matlab contour function uses interpolation and therefore returns a DOUBLE contour line instead of Integer coordinates.
Message 5 of 8
(5,980 Views)
A function much closer to the Matlab one is included in LabVIEW 2011: Contour Line which is under the Mathematics/Geometry/Computational Geometry palette.  This works on 2D DBL arrays.
Message 6 of 8
(5,968 Views)
Greg,
Thanks for the update. That's good to know.
What is the input 'Height' for? Contour line is in a 2-D image.
Message 7 of 8
(5,958 Views)
Height specifies the value at which you want a contour.  Think of your 2D array as Z-values at a range of X-Y locations - then Height is the value of Z for contouring.  This is a polymorphic VI, so you can also provide an array of heights, or ask for a certain number of contours, and the heights will be automatically selected.  If you use those options, then the height of a given contour is returned in the Contour Line cluster as shown.
Message 8 of 8
(5,947 Views)
