What determines whether the Label name and/or Caption appears in the context help window but in other cases, both the label and caption appear in the context help window?
I am trying to polish an application, and find that I cannot seem to reliably control which of the label or caption text appears in the context help window because I don't understand what rules are in place to determine which should appear. It seems like if I reate a named constant, then use it's right click menu command "Create Indicator" I get a control with only a Label (as long as I don't add a caption). This then appears in the context help window as the label name followed by the description text (after entering some description text). But if I add a caption, the label name is shown in bracket
s which is a 'feature' I would like to avoid, because I have certain controls where I would like to use a descriptive variable name on the block diagram side without using so much space on the front panel. It seems like there is no way to avoid showing the Label name in the context help for a control/indicator. Is this true?
I thought the purpose of having a seperate caption was to make the text that appears with a control programmatically controllable, but if that control is not extended to what appears in the context help window, it limits the usefulness of the caption and forces me to re-consider some Label names. However, the problem goes deeper than that because then even when I make the label and caption exactly the same, or if I delete (via a select caption text-backspace or select caption text- delete key .. sequence) the caption for a control, the label name in the context help window still appears in square brackets!
Can I have complete control over the context help fo
r a particular control (or has anyone found a third-party context help solution that functions compatibly with LabVIEW 7 in a built application that they will be so kind as to recommend?)
I have used LabVIEW for three years, and I am now using LabVIEW 7.0.
(2,710 Views)
Sorry for that.. I was changing the text of my question and didn't read carefully enough in the preview stage. I wanted it to read "What determines whether the Label name and/or Caption appears in the context help window?"
(2,710 Views)
To answer my own question, it seems like only the caption appears after the application has been built or even while the VI is running. The brackets only appear while editing the VI.
(2,710 Views)
