What does Vsrc means?
Right now I am using Keithley source meter, and using Labview to control it, but I do not know what does Vsrc means, which is displayed on the screen of the sourcemeter. Thanks for answering.
(5,830 Views)
Probably means Voltage Source but since you have the instrument and manual, it should all be explained there. Not a LabVIEW question.
(5,827 Views)
Are you referring to a VI "screen", or the actual screen of the sourcemeter? If it's the sourcemeter... have you looked in the manual? If you don't know how to use the instrument and you don't have the manual, go to Keithley's web site and download it. You should know how to use an instrument that you're trying to control.
(5,822 Views)
Accepted by Perry_Liu
The SMU is displaying its operational mode Voltage SouRCe.
The Knights are offering some pretty sound advice-  read the manual.  its the best way I know to learn about the tools you use.
I have read the manual- so I do know the answer
(5,810 Views)
Thanks guys for answering my question.
(5,798 Views)
